LabWindows/CVI
Sending email via smtp.gmail.com
Is there any way to send an email via a smtp server (ex. smtp.gmail.com) that requires TLS?  I tried to use the InetSendMail function but it fails (error=-7).  BTW, I'm using LabWindows/CVI version 8.1.1 and 8.5
(4,273 Views)
InetSendMail does not support TLS (or SSL). If you do not mind using .NET 2.0, then the System.Net.Mail.SmtpClient class in the System assembly lets you do this - this class is new to .NET 2.0. You can call .NET assemblies from CVI by creating a wrapper for the assembly using Tools >> Create .NET Controller - it will take a while to generate and compile the wrappers for larger assemblies. If you cannot or do not want to use .NET then you may be able to find open-source code or C libraries that do TLS.
(4,250 Views)
