LabWindows/CVI
Sequence Labview to use as a virtualized bubble. is this possible?
I am trying to use vmware workstion to sequence a labview installation on a XP or W7 image.
I get no errors sequencing Labview 8.6. But importing de sprj file (2.6 GB) in SCCM does. Unfortunately I cannot test the sequenced application without SCCM. Has anyone succeeded in creating a Labview bubble? As you already guessed, installing Labview 8.6 in a virtual desktop went without problems, even connecting tot the (not virtual) VLM.
thanks in advance
Ruud
(3,031 Views)
Hi Ruud,
it appears that you have used the wrong forum; you have posted your question in the CVI/LabWindows forum. The LabVIEW forum can be found here
(3,029 Views)
Accepted by topic author ruud habets
thanks i will move the question
(3,025 Views)
