LabWindows/CVI
Serious UIR selection bug
Hello all,
I hope you can reproduce this bug as well as I do because this is major bug.
In the user interface editor, I have a large canvas with a loaded image that covers the entire panel (1200x800). It's used as a background with a whole bunch of controls on top (about 150). When I start selecting controls with Shift-Clic, the entire PC locks up after about 4~5 selections. The only thing I can do is press Reset on the mobo! If I move the canvas out of the way, it doesn't happen.
I've had problems with corrupted UIR files in the past, but that's a recently created one.
Using CVI 2012.
(3,374 Views)
Does this issue occur when there isn't the loaded image behind all of the controls you've placed on the UI panel?
Ian M.
(3,345 Views)
I had 5 crashes due to this in 2 days last week, but today I can't make it happen again, even though I haven't closed CVI since the last one. Will post again if I can reproduce it.  Smiley Frustrated
(3,299 Views)
Are you running this program with other programs running at the same time? It might be that your available RAM space is limited and having other open software applications causes these issues.
Ian M.
(3,291 Views)
