LabWindows/CVI
Set Gain GigE Camera
Programatically Set Gain GigE Camera
LabWindowsCVI 2013
NI_IMAQdx 4.3
Camera Basler acA640-90gm
I've tried two different approaches for setting the raw gain programatically and neither appear to work.
I can set the raw gain just fine in NI-MAX, but can only see how to save a single camera configuration, typically "cam0". I can rename the one camera config, but there is still only one.
I can also save the icd file as another name in NI_MAX, and with this method, it looks like I am saving the config with another name, but I can only open the most recent one saved, and NIMAX only ever shows the most recent one saved.
The other method attempts to set the gain programatically from CVI with a call to imgGetCameraAttributeString (gSessionID, "RawGain", &gain, sizeof(gain)).  That  returns error 1074397163 "The passed in interface or session is invalid". I get the same error whether I do "int gain;" and pass "&gain", or "char gain[120} and pass "gain".
Thank you,
d
(5,094 Views)
Are you trying to create more than one ICD file for the same camera? If so, I do not believe that is possible. You could create a configuration in MAX and then export it as a saved file which you could access later though.
When it comes to your error in CVI, have you tried to manually add a function prototype at the top of your project?
imgGetCameraAttributeString (SESSION_ID Session_ID, char *Attribute_String, char **Current_Value, unsigned long Current_value_string_size);
If that does not work, how did you define gSessionID before you called it?
Erin D.
(5,049 Views)
