LabWindows/CVI
Set application file name in source code
in some projects i use the same software, only with different interfaces, or sometimes with customized panels. Within the sourcecode i just activate or deactivate the functions i need with defines, f.e: #define USE_TCP...and  #ifdef USE_TCP...........#endif.
Is it possible to set the application name in source code (instead of BUILD -> TARGET SETTINGS) ?.
I'm lookink for something like
#idfef UART_TARGET........project_uart.exe
#elif defined TCP_TARGET........project_tcp.exe
#else ............... project_standard.exe
#endif
in other compilers (for microcontrollers) i can do something like this with #EXPORT (HEX, FILE=HEX_FILENAME)
Any ideas?
Thanks and greetings from Bremerhaven, Germany
Norbert Rieper
(3,670 Views)
Hi ,
I don't know if it's possible but you can save file names / directory as a simple char fileName[256] ,
You can make a simple code that scan a designated directory and choose the file you need....
Still maybe one of the CVI Developer's will give you the best answer , base on my C knowledge i don't it's possible....
Kobi Kalif
Software Engineer
(3,635 Views)
Hi Kobi Kalif,
thanks for trying helping me.
I'm not looking for source code to find a particualar file at runtime. I'm looking for a compiler command within my source code to generate a exe-file with a predefined name.
Norbert Rieper
(3,612 Views)
Ohh....
Well there is the :
CVI_AppBuildProject (CAObjHandle objectHandle, ERRORINFO *errorInfo, long *returnValue);
But it's only for build with no names support , that's what I know but maybe there is something else which I don't know of.....
One more thing - At the menu Build > Builed Steps
there you can define your options at 3 stages :
  • Custom Build Actions—Actions that occur immediately before LabWindows/CVI starts dependency checking after you initiate a build.
  • Pre-build Actions—Actions that occur after LabWindows/CVI checks for dependencies and before it builds the target. Pre-build actions occur only when the target needs to be built.
  • Post-build Actions—Actions that occur after the target is built. Post-build actions occur only when a build is successful.
Try over there maybe it will help you....
Kobi Kalif
Software Engineer
(3,609 Views)
