LabWindows/CVI
Set color of the tab label text
Hello ,
Can set the color of the tab label text ? Because of each default font color is black , hope can modify it, thanks.
David
(4,153 Views)
Use EasyTab_SetAttribute to set ATTR_EASY_TAB_LABEL_COLOR or ATTR_EASY_TAB_BG_COLOR.
Look at the sample project ...\CVI\samples\userint\custctrl\easytab\tabdemo.prj. When you run it and right-click on any tab, you can change the tab properties, including font color. In the demo, right-click >> Properties >> Font >> Label Color changes the color of all tabs on the tab control. Right-click >> Properties >> Tab Attributes >> Label BG Color changes the color only for the background of the selected tab.
(4,140 Views)
Hello David,
Currently, I have not found a way to set the label text color on a Easy Tab control. The 5 attributes you can set for a tab of a tab control are Tab Visible, Tab Dimmed, Tab Label Text, Tab Label Background Color, and Tab Color.
If you are want to highlight a tab when it is active, you might consider either dimming all the other tabs so that the active one stand out, or changing the background color of the active tab.
I hope this helps.
Wendy L
LabWindows/CVI Developer Newsletter
(4,139 Views)
Hello David,
Correction to my previous post: As Al S said, you can change the font color for all the tabs by creating a metafont, but this technique does not allow you to specify different font colors for each tab.
Wendy L
(4,138 Views)
Thanks Wendy and AI S.
David
(4,130 Views)
