LabWindows/CVI
SetActivePanel and EasyTabs
I'm using the EasyTab functions to create a tabbed user interface in LabWindows/CVI V7.1. Sometimes, I require these tabs to be programmatically selected, and I use the SetActivePanel() function for this. The desired panel is always made active, but its associated tab is not redrawn in the raised 3-D graphical format, as would happen if activated by clicking on the tab. Instead, the tab of the panel that was active before SetActivePanel() is called remains visually unaltered so that it appears that the contents of the tabbed panel have changed rather than the actual panel itself. Is there a work-around for this?
John.
(4,314 Views)
I never used the EasyTabs, but I guess using the  EasyTab_SetAttribute function with the  ATTR_EASY_TAB_ACTIVE_PANEL attribute instead of using SetActivePanel might solve the problem.
(4,314 Views)
Thanks for the suggestion. This seems logical, but ATTR_EASY_TAB_ACTIVE_PANEL is an invalid attribute for this function.
John.
(4,306 Views)
This should have worked.  Any chance you have the function parameters out of order?
EasyTab_SetAttribute(panelHandle, TabControlHandle, ATTR_EASY_TAB_ACTIVE_PANEL, HandleOfPanelInTab Control );
(4,301 Views)
Indeed I had them out of order mrv. It works perfectly, thanks.
John.
(4,277 Views)
