LabWindows/CVI
SetCtrlAttribute only works during debug!
Hi Folks,
Having a bit of bother with SetCtrlAttribute for a text box & some
buttons on my UIR. Basically, during execution of a do while loop, I
have a couple of SetCtrlAttribute lines which set these controls to be
dimmed (as they are inoperable during this loop). Strangely, they do
not dim - unless I interrupt the program (Ctrl + F12) - whereupon they
dim immediately.
I am using SetCtrlAttribute in other lines in the same section of
code, in exactly the same way, to change the colour of LED controls.
These function correctly!
Any thoughts ?
BTW running CVI 4.01 on NT4.0
TIA
Craig Jackson
(3,369 Views)
Updating of the user interface is not executed during while loops unless you put inside the loop a ProcessDrawEvents () statement.
For the same reason, detecting user interface events (button clicks and so on) is not possible unless you put inside the loop a ProcessSystemEvents () statement. This statement updates also the user interface (so the use of ProcessDrawEvents is not needed).
Look in the functions help for more detailed reference about them.
Hope this helps
Roberto
(3,369 Views)
Roberto Bozzolo wrote in message news:<5065000000050000002D900000-1027480788000@exchange.ni.com>...
> Hope this helps
> Roberto
Thanks alot Roberto, this has done the trick.
Craig Jackson
(3,369 Views)
