LabWindows/CVI
SetStdioWindowOptions bug on Linux
Hello all,
I added SetStdioWindowOptions() calls to get rid of pesky console popups while debugging, but when I ran the same prog on Linux, it just crashed:
#include <utility.h>
int main(void) {
        SetStdioWindowOptions (1000000, 0, 0);
        return 0;
Compile with cvicc, execute:
$ ./test
Segmentation fault (core dumped)
$ gdb ./test core.2881
(gdb) bt
#0  0xf762571b in ?? () from /usr/local/lib/libcvi.so
#1  0xf72ae597 in ?? () from /usr/local/lib/libcvi.so
#2  0xf741372b in SetStdioWindowOptions () from /usr/local/lib/libcvi.so
#3  0x0804e741 in main () at /tmp/test.c:3
(3,362 Views)
Hi gdargaud,
If you remove that function from your code does the program run?
(3,332 Views)
Well, duh, with just "return 0" in the code, I certainly do hope that it runs !
Anyway, since that function is only useful on Windows, I just surrounded it with a #ifdef _WINDOWS
(3,323 Views)
That function should probably be added to this help doc.
https://www.linkedin.com/in/trentweaver
(3,317 Views)
