LabWindows/CVI
Setting SpaceAfter property with Word ActiveX
Daniel,
I use the document handle for setting other parameters just before the call to the SetLineSpacing function, so I know the handle is valid.  I'm also sending the enumerated constant for single space (although that doesn't matter because the error is thrown before that constant is used).  I managed to get around the problem by using the SetProperty function instead.  My code now looks like this:
** GenerateLogFile **
void GenerateLogFile(void)
    CAObjHandle AppHandle = 0;
    CAObjHandle CurrentSelectionHandle;
    CAObjHandle ParagraphFormatHandle;
    RPTERR(WordRpt_ApplicationNew(VTRUE, &AppHandle));
        // note: DocHandle is declared at file scope
    RPTERR(WordRpt_DocumentNew (AppHandle, &DocHandle));
    RPTERR(Word_GetProperty (AppHandle,
                             NULL,
                             Word_ApplicationSelection,
                             CAVT_OBJHANDLE,
                             &CurrentSelectionHandle));
    RPTERR(Word_GetProperty (CurrentSelectionHandle,
                             NULL,
                             Word_SelectionParagraphFormat,
                             CAVT_OBJHANDLE,
                             &ParagraphFormatHandle));
// generates an error - waiting for feedback from NI Forum
// replaced with following call to SetProperty
//    RPTERR(WordRpt_SetReportLineSpacing (DocHandle, WRConst_Single));
    RPTERR(Word_SetProperty (ParagraphFormatHandle, NULL, Word_ParagraphsLineSpacingRule, CAVT_SHORT, WordConst_wdLineSpaceSingle));
    RPTERR(Word_SetProperty (ParagraphFormatHandle, NULL, Word_ParagraphsSpaceBefore, CAVT_FLOAT, 0.0));
    RPTERR(Word_SetProperty (ParagraphFormatHandle, NULL, Word_ParagraphsSpaceAfter, CAVT_FLOAT, 0.0));
    // generate report content
    CA_DiscardObjHandle(AppHandle);
    CA_DiscardObjHandle(DocHandle);
    CA_DiscardObjHandle(CurrentSelectionHandle);
    CA_DiscardObjHandle(ParagraphFormatHandle);
    DocHandle = 0;
} /* GenerateLogFile */
Message 11 of 15
(915 Views)
Tony,
I don't see in your code where you use the document handle before the SetReportLineSpacing call. Is it elsewhere in the code? I know you said you declare it at file scope, and I see the DocumentNew call to assign the document handle, but I can't see anywhere else that it's used. Does the DocumentNew function return an error code, or does it seem to work properly?
Message 12 of 15
(908 Views)
Daniel,
Sorry, I mispoke.  What I meant to say was that I use the DocHandle to retrieve the other collection handles, and those all work fine.  And no, the DocumentNew function does not return an errror.
Tony G.
Message 13 of 15
(905 Views)
AHAH!!!
In looking over the WordRpt_SetReportLineSpacing code, it seemed odd that it takes a document handle since the other formatting functions take selection or paragraph handles.  So I ran a couple of quick experiments and discovered that if you pass a selection handle to WordRpt_SetReportLineSpacing, it works correctly.  Apparently the function documentation is wrong.  It says to pass a document handle, but it really needs a selection handle.  Here's the final (working, error-free) code:
                             NULL,
                             CAVT_OBJHANDLE,
                             NULL,
                             CAVT_OBJHANDLE,
        The documentation for the following function indicates that the first
        parameter should be the document handle.  However, that generates an
        ActiveX error.  Through experimentation I discovered that if you pass
        the selection handle, it works correctly.
    RPTERR(WordRpt_SetReportLineSpacing (CurrentSelectionHandle, WRConst_Single));
    DocHandle = 0;
Message 14 of 15
(902 Views)
Tony,
That's very interesting--I'm glad your code is working now, though! We'll definitely take a look at that function and update the documentation if necessary.
Message 15 of 15
(896 Views)
