LabWindows/CVI
Setting TestStand Station Globals
We are using TestStand 2013 and LabWindows 2013. Using TestStand, we test multiple products, within an environmental chamber, which take hours to run. We have an issue, where occassionally a unit will fail and we lose communication to it. The timeout delays, waiting for a communication response which will never happen, are causing major issues. My soution is to add a StationGlobal, array of integers- one for each unit being tested, in which I set one of the array elements to indicate that the unit being tested should be aborted. Within TestStand, I check the array element, for the unit under test, to determine if it has aborted or to continue with the testing. TestStand calls a LabWindows module which performs the communication write and read. Within Labwindows, I want to set the FileGlobal to abort when there is a communication failure. The inherited code is far worst than this but that was the simplistic explaination and easiest approach to fix the problem. I do not seek help on how to do the testing as I do not have the luxury of rewritting it.
What I need help on is the exact sequence of calls (module names in order) to connect to the TestStand runtime engine, that is calling the LabWindows module, whatever other modules that I need to execute, the call to the function to set the StationGlobal (I think it is shown below), and then release all of the handles that I used. Without stopping the other threads that are running the other units under test.
            TS_PropertySetValNumber  (TSSeqContext, NULL, "StationGlobals.ManualSlotAbort[0]", 0, 1);
Or better yet or in addition to, is there a link to a manual that explains what the calls are and what they do, in detail?
Thank you for your help.
(4,138 Views)
Hey Bill,
Can you clirify a bit on wether or not you have access to the sequence file to edit it?
You're going to be in a tight spot if you're unable to edit it.
Can you clarfy as well how you want the operation to perform?
Do you just want a unit test to abort if communication has been lost?
I'd check out this as well to see if this is along the lines of what you're thinking:
http://digital.ni.com/public.nsf/allkb/65AACD1BC06D6D3986256BC80050CFE2
(4,117 Views)
After more searching of the internet, the NI forums, and looking through the .h files, I finally found what I needed. I am enclosing the code to help others and to keep a record in the event that I may need this information in the future.
   ViStatus            EndOfResponse      = VI_FALSE;
   CAObjHandle   EngineHandle          = 0;
   ERRORINFO    errorInfo;
   CAObjHandle   GlobalsHandle         = 0;
// Loss of communications? STOP the testing for the slot
   if (EndOfResponse == VI_FALSE)
      TS_NewEngine(NULL, &EngineHandle);
      if (EngineHandle != 0)
//       get a handle to the StationGlobals
         TS_EngineGetProperty (EngineHandle, &errorInfo, TS_EngineGlobals, CAVT_OBJHANDLE, &GlobalsHandle);
         switch (Slot)
            case 0:
               TS_PropertySetValBoolean (GlobalsHandle, &errorInfo, "ManualSlotAbort[0]", 0, 1);
               break;
            case 1:
               TS_PropertySetValBoolean (GlobalsHandle, &errorInfo, "ManualSlotAbort[1]", 0, 1);
               break;
            case 2:
               TS_PropertySetValBoolean (GlobalsHandle, &errorInfo, "ManualSlotAbort[2]", 0, 1);
               break;
            case 3:
               TS_PropertySetValBoolean (GlobalsHandle, &errorInfo, "ManualSlotAbort[3]", 0, 1);
               break;
         CA_DiscardObjHandle(GlobalsHandle);
         CA_DiscardObjHandle(EngineHandle);
      return VI_ERROR_CONN_LOST; // Return an error condition
(4,108 Views)
