LabWindows/CVI
Setting 'Title Bar Visible' to false does not work
Nobody seems to take me seriously, my comment here remained ignored... Smiley Wink
In fact I have a complex UI (with several panels, including tab panels) which when loaded displays the title bar, even if the check mark is removed.
Is there another setting that overrides this? I could not find any hint in the docs.
CVI2013 f1
The code:
    if ( InitCVIRTE ( 0, argv, 0 ) == 0 ) return ( -1 );
    SetSleepPolicy ( VAL_SLEEP_SOME );
    LoadPanel ( "notitlebar.uir", PANEL, &main_panel_handle );
    if ( main_panel_handle < 0 ) return ( -1 );
    DisplayPanel ( main_panel_handle );
    RunUserInterface ();
Message 1 of 9
(6,262 Views)
Hello
Message 2 of 9
(6,258 Views)
Hello NeluF,
Thanks!. I've uploaded the project as titlebar_wolfgang.zip to the ftp / incoming directory. I couldn't prepare a stripped-down version because of the many controls all requiring their callback functions.
Message 3 of 9
(6,252 Views)
Hello
Message 4 of 9
(6,248 Views)
OK, I can add the following:
if I remove the build folder and recompile everything, I get the desired behavior: no titlebar. OK
Then I set the checkmark, compile and build again: no titlebar : WRONG
It appears that I have to delete the build folder to have the change actually happen...
It also works if I choose to rebuild the project
It might be the same bug as reported here
Message 5 of 9
(6,237 Views)
Hello NeluF,
does bug id 433769 also refer to this? Have you been able to reproduce it after the initial build?
Thanks!
Message 6 of 9
(5,912 Views)
Accepted by topic author Wolfgang
Hello
= Nelu F. || National Instruments.
Message 7 of 9
(5,872 Views)
Good to hear, thanks!
Message 8 of 9
(5,869 Views)
It appears that this issue has been resolved in CVI 2013 SP1.
Message 9 of 9
(5,452 Views)
