LabWindows/CVI
Setting close control causes screen flicker
When I disable/enable the close control (x) using the SetPanelAttribute(handle, ATTR_CLOSE_ITEM_VISIBLE, 0), I get a noticeable screen flicker. Is there anyway to update the control without getting the flicker?
(3,578 Views)
I tried to reproduce what you described but I don't see what you describe. I can set the ATTR_CLOSE_ITEM_VISIBLE to 0 and it behaves as documented but I do not see the flicker.
Do you get this behavior for your specific application or for any application. If you can test this out with a simple application that doesn't do any thing else, we can try to narrow down the problem.
Jack J.
(3,560 Views)
Hello Jack,
I
(3,544 Views)
Hello Jack,
I did some more experimenting with the ATTR_CLOSE_ITEM_VISIBLE feature to see if the flicker was only occurring with that specific program. I first tried the program on another computer to see if it was hardware specific. The flicker did occur, so ruling out hardware. I then coded up a simple program with a panel that just had a button that toggled the ATTR_CLOSE_ITEM_VISIBLE on and off. When I ran this program there was no flicker. I then started adding text boxes and graphics to the panel and got the flicker back. When you created your test program did your panel have other things on it?
(3,541 Views)
