LabWindows/CVI
Setting margins of a Label printer
I have just purchased a DYMO LabelWriter 450 to print name badges.  DYMO has an SDK, but it doesn't support ANSI 'C'.  I can print to it using PrintTextBuffer, but the margins are very large reducing my print area.  Is there any way to reduce the margins?
(14,863 Views)
Hi jrbecker,
PrintTextBuffer just sends whatever’s in the text buffer (characters stored as bits) to a printer or file. You can’t specify any sort of formatting for it, like text size or margins. I don’t think there’s going to be a way to do that just in ANSI C without interacting with the device’s API. Those things will be controlled by functions specific to the device that are probably contained in the SDK.
Kelsey Johnson
(14,843 Views)
kelsey,
I took care of my formatting issues by writing everything to a panel with diffent fonts and sizes and then doing a PrintPanel. I'm just left with a 0.3 inch margin which is too much for a 1.2" label.  I'll try to find a DYMO SDK expert and see if they can write me a small exe that sets the margins to zero.
(14,838 Views)
Thank you for the observation, we are going to take into account.
Just to make sure you know: DYMO has a blog for developers, developers.dymo.com, where there is quite a lot of useful information on configuring LabelWriters.
(14,810 Views)
DYMOsupport,
I checked the BLOG and could not find anything that would help me.  It would be nice, for those of us that can't use the SDK, if DYMO had a command line executable that took parameters to allow users to set some of the more commonly used printer parameters.  That way we could call it from our code.
(14,789 Views)
Hello jrbecker,
Have you tried creating a .NET Controller in LabWindows/CVI?  You can access this feature by selecting Tools»Create .NET Controller.  This will allow you to choose a .NET assembly and create a LabWindows/CVI wrapper automatically.  The help document for this feature can be found here: Create LabWindows/CVI .NET Controller Dialog Box.
I installed the SDK for DYMO as a test, and it seems to install a .NET assembly in its <dotNET Samples> directory. The DLL is called Interop.Dymo.dll.
Once you create the .NET Controller, you can call into the SDK from LabWindows/CVI.
I hope this helps,
Daniel Dorroh
(14,759 Views)
