LabWindows/CVI
Setting the byte alignment at the project level
Is there a way to set the byte alignment at the project level, for example a project setting.  I see the __DEFALIGN macro in the predefined macros which changes based on the compatibility mode I select but how do I change that default setting
(3,107 Views)
Look at the #pragma pack directive, described  in the LabWindows/CVI Programmer Reference Manual.
Here is an excerpt from the chapter titled Compiler/Linker Issues:
Structure Packing
example:
#pragma pack (4) /* set maximum alignment to 4 */
typedef struct {
char a;
int b;
} MyStruct1;
typedef struct {
char a;
double b;
} MyStruct2;
#pragma pack () /* reset max alignment to default */
LabWindows/CVI predefines the __DEFALIGN macro to the default structure alignment of
the current compatible compiler.
(3,096 Views)
