LabWindows/CVI
Setting up Default File Search Path (Directory) for CTRL+F, Multiple Files...
Hello Labwindows Community,
Using Labwindows 2012.
When you hit CTRL+F to find a phrase, and hit the "Multiple files..." checkbox, is there a way to set-up the default directory during the search? At the moment, the CTRL+F option remembers the last directory where the CTRL+F option was used (this could be for a previous project that I have opened rather than the current project opened).
Was there a way that the default directory for CTRL+F is the folder that contains the current project rather than the previous project? I am not sure if I have some setting turned on without knowing.
Vincent
(2,871 Views)
Hi VincentTang,
As far as I know, there is no way to set up a default search directory that will get searched with Ctrl-F. All environment options can be found in the documentation linked below:
Options»Environment
http://zone.ni.com/reference/en-XX/help/370051V-01/cvi/usermanual/prjenviron/
Applications Engineering
(2,826 Views)
Hi SaileshK,
Thanks for the input! I will play around with the Environment options to see if there is a happy alternative.
Vincent
(2,821 Views)
