LabWindows/CVI
ShellExecute(
Hello
I have two applications where one works but not the other. I've also looked through previous questions about the issue.
In the application that does not work I do as followc
1: include the shell32,lib from  C:\Program Files (x86)\National Instruments\CVI2013\sdk\lib\msvc to the project
2 : include < windows.h> and < shellapi.h>  in the .c file where it is used
3: call ShellExecute(NULL,NULL,"mail to;post@fluidtronic.com",NULL,NULL,0);
The only difference between my two apps. is that in the one that is not working the call to ShellExecute() is from
a panel callback and in the other from a control callback.
(5,271 Views)
ShellExecute()  from MSDN:  A handle to the **parent window** used for displaying a UI or error messages. This value can be NULL if the operation is not associated with a window.
I wonder if there might be a relationship to this being called by your main panel?
Have you tried passing NULL in the panel argument?
(5,228 Views)
Spoke too soon, I see that you DID pass NULL in that argument.  Ugh.
(5,227 Views)
I found the problem. I wrote "mail to;" instead of "mailto:" My own stupid misstake. Thanx anyway
(5,217 Views)
