LabWindows/CVI
Shortcut to navigate source code browser?
Hello all,
when you have several results in a (Ctrl-F) search and you are in the editor, you can go to the next one with F3.
When you have several error/warnings after a compilation and you are in the editor, you can go to the next one with F4.
When you've used Ctrl-F1 to list the use of a variable/function and you are in the code, is there a shortcut key to go to the next one ? Or is it possible to associate a shortcut ?
Message 1 of 1
(2,786 Views)
