LabWindows/CVI
Show trace name on mouse over
i want to show the trace name (the same name as the legend text) when the
user moves the cursor over a trace within a graph. Something like the
TOOLTIP Element, just a small text that appears next to the cursor and show
the name of the trace.
Thats because i have a graph with about 50 traces plotted and the user is
looking for an easy way to identify the trace.
Any ideas ?
Thank You
Norbert
Message 1 of 8
(4,435 Views)
Hi Norbert,
in principle... it can be done using the function GetGraphCoordsFromPoint; but then you would need to compare these coordinates with all your plot data which seems quite time consuming; while it is possible displaying the mouse coordinates this way it will not work to correlate it with a graph in real time...
Wolfgang
Message 2 of 8
(4,431 Views)
If you have Graph Cursors which are set to snap to the nearest plotted point, you can use GetGraphCursorIndex() to find which plot the point belongs to. It is then a simple matter to PlotText() with a suitable string at the cursor position, looping until the mouse button is released, and then DeleteGraphPlot() on the text just plotted.
JR
Message 3 of 8
(4,429 Views)
Attached simple project illustrates the approach. Not exactly a popup - you need to left-click on the graph to get the description, then right-click when you have finished with it. Note the cursor colour has been set to Transparent, to avoid unnecessary clutter.
JR
Message 4 of 8
(4,410 Views)
Hello Wolfgang, hello jr_2005,
thanks for your help. I hoped that there is a buil in function that i didn't
see, but ok........so i have a little programming work to do 😉
Norbert
"Norbert Rieper" <nrieper@isitec.de> schrieb im Newsbeitrag
news:4ca5d851@PYROS.natinst.com...
> Hi,
> show the name of the trace.
> Any ideas ?
> Thank You
> Norbert
Message 5 of 8
(4,365 Views)
Norbert:
I took JR's excellent example and expanded on it to do ID by mouseover.
I key it off EVENT_MOUSE_POINTER_MOVE.
I get a graph coordinate from the mouse coordinates using GetGraphCoordsFromPoint().
I use SetGraphCursor() to put a cursor at the mouse pointer, but then I turn right around and use GetGraphCursor() to move the cursor to the closest point on any plot (without me having to talk to Mr. Pythagoras!).
For development and demo purposes, I added options to Plot new data (randomized or not), and ID by click or ID by mouseover.
Play with the attached example and see if that's an approach that works for you.
Thanks for the great start JR!
Message 6 of 8
(4,344 Views)
Hi Al S,
that was exactly what i was looking for. Thank you very much, you saved me
some programming time...thanks 🙂
Norbert
"Al S" <x@no.email> schrieb im Newsbeitrag
news:1286473213392-1272222@exchange.ni.com...
> Norbert:
> &nbsp;
> &nbsp;
> &nbsp;
> for you.
> &nbsp;
> ID_Plot.zip:
> http://forums.ni.com/ni/attachments/ni/180/49338/1/ID_Plot.zip
Message 7 of 8
(4,330 Views)
Hi Norbert,
now that you found your solution you should mark the thread as solved. And you should even consider donating some kudos to Al and JR recognizing their efforts and time and providing such valuable feedback.
Message 8 of 8
(4,321 Views)
