LabWindows/CVI
Signal Generator
Which is the best way to generate a swept sine signal from 1Hz to 1Khz ?
(3,556 Views)
Carlos
There is not an easy way to generate a swept sine signal with CVI. The only way to do this is to use the SineWave function in a loop and change the Frequency as needed.
Brian Lewis
(3,556 Views)
Thank You and What do you think about the Sinc Wave function?
"bman" wrote in message
news:50650000000500000030410000-999158726000@exchange.ni.com...
> Carlos
> Brian Lewis
(3,556 Views)
