LabWindows/CVI
Similar function like GetModuleDir in ansi c ?
I wrote a cvi application that will be called from another application based just on ansi c. Actually I would like to make sure wherever the application is on harddisk, it becomes the right path (with a function like GetModulDir from CVI) but just written in ansi c.
Thanks for help.
(3,636 Views)
Not in Ansi C as far as I know. You will have to build it yourself I guess.
Jattie van der Linde
Engineering Manager, Software & Automation
TEL Magnetic Solutions Ltd
(3,612 Views)
Well, any Ideas ?
(3,605 Views)
No Sorry! There was'nt a lot of complicated file stuff going on in the Ansi C days, it was DOS based and simple.
What's you objective behind using ANSI C?
(3,575 Views)
