LabWindows/CVI
Simple table manipulation/data manipulation with Access DB
I am a very raw programmer and am also very new to LabWindows CVI and I would appreciate any information I can attain on gaining access to a MSAccess database via CVI. Already created ODBC source.Do I need a separate SQL driver?Can someone show me some sample code that shows where the sequel statements need to go and basically show how to manipulate tables. I know that this is pretty low-level but I will truly appreciate any help I can get. Thanks.
(3,195 Views)
First of all did you buy the SQL Toolkit and if so check out the Reference Manual on the NI website 320960A.pdf It contains good examples and a nice overview that gets you into the functionality quickly. Secondly, do you know SQL. There's a lot involved in setting it up and getting it going but there also a lot of tricks to make it easy. check out the manual or let me know and I'll mail it to you directly.
Jattie van der Linde
Engineering Manager, Software & Automation
TEL Magnetic Solutions Ltd
(3,195 Views)
