LabWindows/CVI
Simplest way to draw a vertical line on panel
Hi
I'm wondering what's the simplest way to draw a vertical line? Could you give me an example?
(4,551 Views)
If you want to plot the vertical line directly on a panel then you can chose either a splitter control or a transparent canvas with a vertical line (for drawing on a graph you can use PlotLine ()).
The question is if you want to do this interactively in the UI editor or programmatically.
(4,546 Views)
Thanks for the info, I would like to UI editor, currently I used splitter to draw a horizontal line, how to draw a vertical line
using splitter?
(4,542 Views)
Accepted by topic author lynnz
Ah, when selecting the control chose the vertical one Smiley Wink
(4,540 Views)
Now I see itSmiley Tongue. Thank you!
(4,532 Views)
