LabWindows/CVI
Simulate Movement (rotation,translation) of object with images or similar
Hello guys, I'm trying to develop an app where I specify certain distance (in pixels or similar) so an image or object can move in the Y and X axis and can also rotate. For example Move 9 , Rotate 50, Move Backwards 39. Is this possible in Labview and if so what's the easiest way in your opinion I can accomplish it?. I appreciate any link or info you can provide me so I can start with the development, thanks in advanced !
(4,834 Views)
Since you say LabVIEW you should post this question to the appropriate forum
(4,828 Views)
Reposted in the LabVIEW board
(4,796 Views)
Hola
Puedes intentar usar este ejemplo
Exito
(4,771 Views)
