LabWindows/CVI
Simulation of CTRL key holding with a Toggle Button
I know I can emulate a keyboard key press with FakeKeystroke( ) function.
But is there a way to simulate a key holding down (CTRL, or ALT for example)?
So that when the user left-click, a CTRL+left-click event is generated.
In a touch screen application the user can only generate a left-click event, so the modifier keyboards keys must be simulated.
I've been thinking about a Toggle Button representing the key pressed or not, but I don't know which function I should use inside the button callback.
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(4,513 Views)
In the control callback you can test the value of the toggle button and decide what to do depending on its state:
case EVENT_LEFT_CLICK:
    GetCtrlVal (panel, PANEL_TOGGLEBUTTON, &sts);
    if (sts) {
        // Code for modifier key on
    else {
        // Code for modifier key off
    // If you want to turn off the modifier key:
    SetCtrlVal (panel, PANEL_TOGGLEBUTTON, 0);
    break;
(4,508 Views)
Your suggestion seems OK, but the problem is a little bit more complicated.
I'd like using the movectrl function MakeMovableControl( ) without modifying the movectrl.fp source file, so I need to simulate a real CTRL holding, so that CTRL+left-click is sent to the control callbacks chained by MakeMovableControl( )...
Vix
Using LV from 7
(4,502 Views)
Oh, I see! This is a completely different scenario I didn't figured out...
I'm afraid I have no suggestion at the moment.
(4,499 Views)
