LabWindows/CVI
Simultanioues Out on two Different channel
We have PXI 6711 . We need to generate sine wave and the DC voltage on two different channel . Is is possible to do this using traditional niDAQ . Pl help me with this . I tried this but getting an error say resource sharing . The software used is CVI
Apriciate your help
Sharanu
(3,038 Views)
Hello Sharanu,
I was able to find an old example written in Visual C++ 6.0 that performed double buffered waveform generation on multiple channels with the 6711. The main purpose of this example is to give users an idea about programming the waveform generation on multiple channels using NI-DAQ C function calls and interleaving the data before performing the waveform generation. I hope that you are able to find this example useful.
Best of luck.
Jared A
(3,038 Views)
