LabWindows/CVI
Size of text plot
I have plot text on a graph using PlotText function. I want to change the size of the the text but couldn't find the way to do it. It would be nice if somebody could give me an advice.
(3,202 Views)
You first create a new MetaFont using the CreateMetaFont() function. E.g. to create a plain 9 point Arial MetaFont you could do:
CreateMetaFont("Arial9","Arial",9,0,0,0,0);
The you use the new font name as the MetaFont parameter in the PlotText() function:
PlotText(panel,control,xpos,ypos,"Some Text","Arial9",VAL_BLACK,VAL_WHITE);
Martin.
Martin
Certified CVI Developer
(3,199 Views)
