LabWindows/CVI
Slow Compilier
Whenever I need to recompile code the compiler is very slow it used to be much faster than this. What's up?
Greg
(3,096 Views)
Hi Greg,
I'd first check the watch window before compiling to make sure it's clear; sometimes it can slow down compiling time. Also, can you determine whether the delay is in compiling or linking? It may be that going through some library files may take longer than expected, or even references to header files within these other files. I would see by taking out parts of code to determine where the lag originates from. Hope this helps!
Jeremy L.
Jeremy L.
(3,079 Views)
