LabWindows/CVI
Software crashes with [FATAL] [GetUILSpace] [..\james\ui_tag.c:739] Assertion failed: uiData->uilSpace != 0
So, if I interpret the profiler correctly, my software really does practically nothing on this test setup. I use the profiler for the first time though, so I don't exactly know how to use it. I have added CVIProfSetCurrentThreadProfiling(1); at the start of every thread (WinMain aswell) and that's it.
This is the only thing that thImageSaver did (apart from some init things at the start):
And this is was WinMain mostly did (apart from some init things at the start):
Again, I merely started the application up, let it do its startup things and then moved the mouse around for about 5-10 minutes until the performance dropped.
The 2020 runtime seemingly prevents this issue, unless it only happens after a lot of hours, which I haven't tested yet.
Message 11 of 13
(640 Views)
@gdargaud wrote:
It's not just a licensing problem, it's a linking problem. Function signatures may not match and it'll either refuse to run outright (if you use InitCVIRTE) or will crash when calling certain functions.
I use InitCVIRTE and also there was a question about RTE backwards compatibility on this forum:
https://forums.ni.com/t5/LabWindows-CVI/Question-about-mixing-LabWindows-CVI-runtime-versions/td-p/7...
To add clarity: I am developing using CVI 2017, the runtime where the application starts to slow down is 2017, the runtime where it does not is 2020.
Message 12 of 13
(638 Views)
AFAIK there are no licensing problems in installing whichever runtime version you want to. And I have never find any issue till now in running an application with a RTE more recent than the IDE the application was compiled into.
Message 13 of 13
(611 Views)
