LabWindows/CVI
Some questions on SingleToneInfo()
Hi Vix,
440964 relates to the incorrect behavior when passing 0 as the frequencyWidth.
Let me follow up with the team to have them investigate the behavior you are experiencing when setting valid parameters.  If you can provide an example of some parameters which reproduce this erroneous behavior every time, that might help speed up the process.
Daniel Dorroh
Message 11 of 12
(1,128 Views)
It takes me some time to provide an example, but I think it would be possible
Let me know about the investigation with the team
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
Message 12 of 12
(1,113 Views)
