LabWindows/CVI
Source code file getting over written after editing uir
I have a standalone exe project using the user interface LabWindows CVI 6.0.
Lately when I edit the UIR file, my .c file gets overwritten with the following data.
#pragma pack(4)
typedef struct {char *name; void *address; unsigned long isFunction:1; unsigned long reserved:31;} ExeSymbol;
int __cdecl EditTableDataEvent (int panel, int control, int event, void *callbackData, int eventData1, int eventData2);
int __cdecl FileCancel (int panel, int control, int event, void *callbackData, int eventData1, int eventData2);
int __cdecl GetFileStat (int panel, int control, int event, void *callbackData, int eventData1, int eventData2);
int __cdecl aboutCompanyInit (int panel, int event, void *callbackData, int eventData1, int eventData2);
int __cdecl aboutExit (int panel, int control, int event, void *callbackData, int eventData1, int eventData2);
void __cdecl calLoad (int menuBar, int menuItem, void *callbackData, int panel);
In my project, my source code file is the same name as my UIR, i.e., fileName.prj, fileName.c, fileName.uir.
I have had to change my source code name to avoid loseing data.  This only started happening recently.
(3,200 Views)
This kind of content is usually found in the file generated for external compiler support of the .uir.
You can change this behaviour in selecting Build/External compiler support in CVI IDE.
Nicolas
Message Edité par NicoLeach le 09-04-2008 11:18 AM
(3,179 Views)
