LabWindows/CVI
Specify an alternate location to build the .lib file
CVI: Version 7.0
Is it possible to specify different target locations for a .lib and .dll?
Under target settings the dll path can be specified and the .lib file name can be changed,
but I cannot find the setting to build a lib file to a separate location from the associated dll.
Thanks for the help,
Garth
(2,873 Views)
No, you cannot do that in the Target Settings dialog. The best option would be to create a post-build step that copies the lib file to where you would like it to be. Unfortunately, the Build Steps feature was only added in 7.1, so it's not available in CVI 7.0.
Luis
NI
(2,862 Views)
