LabWindows/CVI
Speed up table cell value change
I am trying to display data in a table as it's retrieved into my PC. I am sampling sequential channels and I need the data to be row-wise. Below is a snippit of code from the function that adds the data to the table.
SetTableCellAttribute (nPanel, nTable, MakePoint(nCol,nRow), ATTR_CELL_TYPE,
VAL_CELL_STRING);
SetTableCellAttribute (nPanel, nTable, MakePoint(nCol,nRow), ATTR_CTRL_VAL,
pIni->pScanInfo->m_szTime);
nCol++;
SetTableCellAttribute (nPanel, nTable, MakePoint(nCol,nRow), ATTR_DATA_TYPE,
VAL_INTEGER);
pIni->pScanInfo->m_nCurrentChannel);
// Then put all the ion currents in to a string
for (i=0; i
pScanInfo->m_nFinalMass - pIni->pScanInfo->m_nInitialMass + 1; i++)
nStatus = Fmt(szScan, "%s<%f", pIni->pScanInfo->m_dDataArray[i]);
ATTR_DATA_TYPE, VAL_DOUBLE);
ATTR_FORMAT, VAL_SCIENTIFIC_FORMAT);
atof(szScan) );
nCol++;
The for {} loop has to put 50-100 items in their cells, incrementing the column after each. I find that the for{} loop alone takes something on the order of 30 seconds to execute. Is there a more efficient way of doing this? Perhaps replacing the MakePoint() functions, which allocate memory each time they are called, with another method would speed things up?
I need this whole function to finish in 1 second or so, not 30 seconds. Is this possible, or is the table going to be forever a time burden on my app
Craig
(4,514 Views)
Hello! It was happened to me too... and
teh best (and simpliest) solution is to put BEFORE your loop the table
in invisibile state with :
SetCtrlAttribute (panelHandle, TAB_TABLE, ATTR_VISIBLE, 0);
end immediately AFTER
SetCtrlAttribute (panelHandle, TAB_TABLE, ATTR_VISIBLE, 1);
Of course the table cannot disappear, simply CVI runtime doesn't refresh
the screen for every attr or value changed. Of course you can't put a
call like ProcessSyestemEvent() or ProcessDrawEvent() in your loop.
Remember that you also optimize speed using functions that affect an
entire range of cells instead one a time like:
SetTableCellRangeAttribute (panelHandle, controlID,MakeRect (2, 3, 5,
5),cellAttribute,attributeValue);
hoping this helps
Ciao
Raf
> table.
> ATTR_CELL_TYPE,
> VAL_CELL_STRING);
> ATTR_CTRL_VAL,
> nCol++;
> ATTR_DATA_TYPE,
> VAL_INTEGER);
> ATTR_CTRL_VAL,
> for (i=0; ipScanInfo->m_nFinalMass -
> ATTR_DATA_TYPE,
> VAL_DOUBLE);
> ATTR_FORMAT,
> atof(szScan)
> nCol++;
> burden on my app?
> Thanks,
> Craig
(4,515 Views)
Thanks for the reply. Shortly after posting, I realized that, since I am using arrays, I could take advantage of the SetTableCellRangeAttribute() function and found that it improved the function time immensely. The 20-30 second update took less than a second.
I still wonder if there is a way to declare a Point variable pointer and use it, to remove the malloc() that must be going on each time you call SetTableCellVal() with the embedded MakePoint().
(4,514 Views)
     I am having the same problem in LabVIEW. How can I overcome this. I have displayed a 7000 x 70 string data in table and it is taking much of the memory and time for processing and display. How can I correct this?
-Vasanth.
Ya Ya
(4,318 Views)
