LabWindows/CVI
Startup Error: Mesa.dll could not be loaded.
Since today I have the following problem when starting my CVI application:
Clicking OK does not solve the problem, the message appears again.
I already tried older installers of the application, but the message still appears.
The last thing i tried, was removing the last installed programs, drivers and windows updates. No changes.
What can i do, to localize the source of the error?
Is there a option to enable some kind of debug output, when starting a CVI application?
Cornelius
Edit: MS Visual C++ RT is installed:
(4,033 Views)
The source is here:
C:\Program Files (x86)\National Instruments\Shared\Mesa
I put an older version of mesa.dll here and it did the job. No more error for me.
(3,997 Views)
this solved my problem too. But is this a problem with a updated Windows component?
It would be bad, if this happens on all Windows PCs in the future.
Maybe a ni employee could be clarify this.
(3,974 Views)
I have the same error with CVI 2017. Where I could find older verion of mesa.dll ?
PC runs on win7 32 bit.
(3,663 Views)
