LabWindows/CVI
Startup Error: Mesa.dll could not be loaded
when starting my CVI application,a popup window is like this
I installed CVI from 2012 to 2017 on my computer before, My computer also has labview 2013 ,When I install new software which use CVI 2017 compiled,a popup window is like that
I'm looking for a solution in BBS,Some one said:
The source is here:
C:\Program Files (x86)\National Instruments\Shared\Mesa
I put an older version of mesa.dll here and it did the job. No more error for me.
I don't have an older version of mesa.dll  , I want to know how I can solve it,
Cornelius
(2,762 Views)
Have you seen tried the suggestions listed in this post ?
1. Install the full CVI runtime with the default settings
2. Leave out the ActiveX module if not needed
3. Install the VS C++ runtime on the deployment machine
(2,740 Views)
