LabWindows/CVI
Store value to file in engineering format
Hi there,
i need to save values to a file in engineering format (f.e. 1.234E-3, or
1234E-6...). Is there an easy way to format the value in engineering format
? If i use a format like (sprintf(val_str,"%1.4e", float_val) I don't get
the engineering format :o(
Norbert
(3,584 Views)
Hello Norbert,
you could use the formatting function Fmt. This line of code will do what you are asking for:
Fmt (val_str, "%f[e]", float_val);
The CVI Formatting and Scanning functions are very powerfull tools. Check the LabWindows help on "Formatting Functions" for more information on this function.
(3,580 Views)
Hello Wim,
im not absolutely sure, but i think i tried this way to, but also the
Formatting Functions didnt work the way i want. Format in engineering
notification meens in steps like 1 E-3, 1 E-6, 1E-9, 1E-12, but not 1E-2 or
1E-5 and so on, so with this format i can get a scientific notification, but
not an engineering. This is important, because i have to think in steps like
mA or nA or uA (milli Amps, nana amperes or mycro amperes)..
Norbert
"Wim S" <x@no.email> schrieb im Newsbeitrag
news:1166195414889-454704@exchange.ni.com...
> Hello Norbert,
> you are asking for:
> function.
> &nbsp;
(3,578 Views)
Hi Norbert,
sorry, I misunderstood your question Smiley Sad I'm afraid the Formatting function is unable to do this. I guess you will have to write your own function for this...
(3,575 Views)
