LabWindows/CVI
Strange EVENT_DISCARD Behaviour
CVI 2019.
I have a couple pretty large apps that have suddenly started acting odd under 2019 in debug on Win10.  When I quit the app EVENT_DISCARD is issued to every Callback function.  Not just once, but infinitely.  I always have to click the red stop button a couple extra times to get the app to actually quit.  I put a case EVENT_DISCARD: in one of the callbacks, with a breakpoint, so I could see this point reached over and over.  At some point a stack overflows or something, because the app goes belly-up quitting at some unknown location.
This does not seem to happen in Windows 7.
Anyone ever see this?  Is there some setting in the IDE I'm missing to prevent this?
Message 1 of 9
(4,352 Views)
I have just installed 2019, so I have not been working yet with my many old programs. Do you do anything in your EVENT_DISCARD cases ? If not, why do you have a case ? And what if you return 1 to swallow the event ?
Message 2 of 9
(4,183 Views)
After a little investigation of why the app never actually quite, I found the EVENT_DISCARD thing.  Added a case to one callback, just to trap it and see that every callback was issued the event thousands of times, until something just failed.  I will try the return 1; but the library .h says the event is not swallowable.
Message 3 of 9
(4,076 Views)
return 1; does nothing.  EVENT_DISCARD continues to be issued thousands of times.
Message 4 of 9
(4,068 Views)
I still need help with this.
Has anybody seen behavior like this?
Message 5 of 9
(3,893 Views)
Where do you call QuitUserInterface() ?
Message 6 of 9
(3,878 Views)
As I mentioned in the first post, this does not happen in Win7, only Win10.
I think this is very standard.
At the end of Main:
	RunUserInterface ();
QuitUserInterface();
DiscardPanel (panelHandle);
return 0;
At the end of QuitCallback:
	Sleep(500);
QuitUserInterface (0);
break;
return 0;
 Perhaps it is routine to send EVENT_DISCARD to every callback during the execution of DiscardPanel(), but it never stops.  It just cycles through all callbacks forever, sending EVENT_DISCARD.
Message 7 of 9
(3,870 Views)
You QuitUserInterface should be in the callback of your top panel(s) in reply to EVENT_CLOSE
Message 8 of 9
(3,866 Views)
I have used exactly the method specified in the RunUserInterface function panel, shown below.  And as outlined in the code fragments posted previously.
int main (int argc, char *argv[])
int status;
if (InitCVIRTE (0, argv, 0) == 0)
return -1; /* out of memory */
if ((panelHandle = LoadPanel (0, "sample.uir", PANEL)) < 0)
return -1;
DisplayPanel (panelHandle);
status = RunUserInterface ();
return 0;
/* additional callback functions here */
int CVICALLBACK QuitCallback (int panel, int control, int event, void *callbackData, int eventData1, int eventData2)
switch (event)
case EVENT_COMMIT:
break;
return 0;
Message 9 of 9
(3,860 Views)
