LabWindows/CVI
Strange behavior for memory allocation with structures
I noticed a strange behavior when allocating memory with structures.
The explanation is unfortunately a bit lengthy that's why it is in the attached Word document.
I attach also a test Program which features this behavior
Thank you if someone can help
Don't hesitate to ask if some additionnel explanation is necessary
(2,879 Views)
I forgot to tell that I'm on CVI2017
(2,868 Views)
Unfortunately you have a lengthy explanation of what you are doing and what does not work according to you, yet you don't provide the source code of your programming.
You mention in your document about modifying the InitMoveData1 function and then it works. According to my understanding of the intended data structure this modified function is the only way that initializing this data would make sense, so not knowing what you have done before the modification, I can't say what your problem is.
Rolf Kalbermatter  My Blog
(2,833 Views)
Sorry, I forgot the C file in the zip file.
Here it is.
Bertrand
(2,828 Views)
