LabWindows/CVI
Strange problem when load a Panel
When I run my program, I was told:
NON-FATAL RUN-TIME ERROR:   "xy2uv.c", line 19, col 24, thread id 0x00000898:
The callback function, message, specified in the UIR file, is not a known function.
If you are using an external compiler, you must include the UIR callbacks object or
source file in the executable or DLL.
I include the main() function in the following:
int main (int argc, char *argv[])
 if (InitCVIRTE (0, argv, 0) == 0)
  return -1; /* out of memory */
 if ((panelHandle = LoadPanel (0, "xy2uv.uir", PANEL)) < 0)
      ~~~~~~~~~~Reporting Error
  return -1;
 DisplayPanel (panelHandle);
 RunUserInterface ();
 DiscardPanel (panelHandle);
 return 0;
The panel can not be seen
What's wrong?
(3,384 Views)
What might be the problem is that you have a callback in one your panels and no corresponding function to that. Try by removing the callback and run. It might work.
Bye
Ashwin
(3,382 Views)
