LabWindows/CVI
String Function Questions
So i know there's probably a million different ways to do this and I don't remember any of them.  How do I do the following:
Message1 = "Why can't I remember anything from C"
Message2 = "from C"
How do I extract the last character (or any number of characters) from Message 1 and then compare it to see if it's equal to message 2?Robot Indifferent
(3,632 Views)
Using ANSI C something like the following should do the trick ( remember: last character of a string  is string[strlen(string )-1])
success = 1;
for (i = 0, (i <strlen(Message2)) && success; i--)
    success = Message2[strlen(Message2) -1-i] == Message1[strlen(Message1) -1-i]
If you prefer to use the NIs libraries you could use CompareStrings with an offset.
CompareStrings( Message1,StringLength (Message1)-StringLength (Message2),Message2,0,1) == 0;
(3,625 Views)
try the simple CVI function:
FindPattern() in Formatting and IO library /string manipulation:
found_at_pos = FindPattern (buffer_to_seach, start_index, num_of_bytes,        "pattern_to_find", case_sensitive, start_at_end);
layosh
(3,589 Views)
