LabWindows/CVI
String comparison CVI If loop
Hello
im using if loop for comparing a char and making decision, but if condition is not working
here is my code
strncpy(BufString, &readBuf[0], 3);
BufString[3] = '\0';
Fmt (outMessage, "%s<%s%s%s","Power supply \"",BufString,"\" ");
MessagePopup ("Status", outMessage);
if (BufString == 'VOL')
Fmt (outMessage, "%s<%s%s%s","Power supply \"", BufString, "\" ");
though value of BufString is VOL, condition inside if loop dosnt execute
(4,195 Views)
In ANSI C, strings cannot be compared with == operator.
You need to use the strcmp function.
S. Eren BALCI
IMESTEK
(4,183 Views)
@ebalci
can you just post a simple example code to use strcmp instead of "=="
(4,177 Views)
This is how you do it
if (strcmp (BufString,"VOL")==0)
where BufString is my string to be compared, and VOL is my Constant
I found it from Stack Overflow
(4,170 Views)
