LabWindows/CVI
Strip Chart history buffer
Hallo,
I have a little crazy question - is there some possibility to access strip chart history buffer?
I'm just lazy to develop data circular buffer management ....
Thanks a lot for any hint!
George
(5,215 Views)
What are you trying to do with the history? The usage would affect how you would access it. I might suggest using an example like this that has a circular buffer that might save time.
Evan See
(5,184 Views)
Hi, Evan,
thanks for reply.
My idea is use already used memory of the strip chart (not duplicate the amount of allocating memory) - mainly to export recorded traces  - e.g. when user decided: "this is interesting - let's make some analysis of this, maybe at home".
The Strip Chart hasn't simple solution to use cursors - and by exporting the history buffer (traces) to some file / array is quite easy use standard graph with cursors etc.
Of course, the cicular buffer is OK.
George
(5,181 Views)
You could support this idea and wait...Smiley Wink
(5,126 Views)
