LabWindows/CVI
StripChart Pause
I would like to pause the graph, but I can't stop it.
I receive data via serial line RS232 can this be affected by this?
When you press the "Pause" button scrollBar appears at the bottom, but the graph does not stop and continues farther, do you know how to do it?
Thank you
	int val;
	switch (event) {
		case EVENT_COMMIT:
			GetCtrlVal (panel, PANELPAUSE_PAUSE, &val);
			SetCtrlAttribute (panelsil, SILY_GRAFSIL, ATTR_STRIP_CHART_PAUSED,val);
			SetCtrlAttribute (panelvy, VYSKA_GRAFVYS, ATTR_STRIP_CHART_PAUSED,val);
			SetCtrlAttribute (panelvyk, VYKYVY_GRAFVYK, ATTR_STRIP_CHART_PAUSED,val);
			break;
	return 0;
Message 1 of 8
(4,716 Views)
ATTR_STRIP_CHART_PAUSED is only valid when the scroll mode is set to continuous.
jan
Message 2 of 8
(4,684 Views)
Hi
I have all 3 charts set to continuous.
Message 3 of 8
(4,674 Views)
Your graph window is set to 1024 points. You have to fill in 1024 points before you can scroll back in time. Make sure that the graph buffer (ATTR_HISTORY_BUFFER_SIZE) can hold more than 1024 points.
Jan
Message 4 of 8
(4,657 Views)
Yes, I changed it to 900 points now and it stopped for a while, until he reached the scrollBar and the graph continued again. How much should I set it then?
How do I use ATTR_HISTORY_BUFFER_SIZE?
Message 5 of 8
(4,646 Views)
Accepted by topic author MajklS
It depends on your requirements. As a start you can set ATTR_HISTORY_BUFFER_SIZE to 10 times the points per screen:
Example
SetCtrlAttribute(hPanel, hCtrl, ATTR_SCROLL_MODE, VAL_CONTINUOUS);
SetCtrlAttribute(hPanel, hCtrl, ATTR_HISTORY_BUFFER_SIZE, 10*1024);
SetCtrlAttribute(hPanel, hCtrl, ATTR_POINTS_PER_SCREEN, 1024);
Jan
Message 6 of 8
(4,640 Views)
Hi, great, it works, but when I click on the "Pause" button, the graph starts from the beginning and then you can scroll and when I click again, the graph starts again from the beginning, do you know why?
Should I put the HISTORY_BUFFER_SIZE setting in a graph or button function call?
int CVICALLBACK CallbackPauseGraph (int panel, int control, int event,
									void *callbackData, int eventData1, int eventData2) {
	int hod, val;
	switch (event) {
		case EVENT_COMMIT:
						SetCtrlAttribute(panelsil, SILY_GRAFSIL, ATTR_HISTORY_BUFFER_SIZE, 10*900);
						SetCtrlAttribute(panelsil, SILY_GRAFSIL, ATTR_POINTS_PER_SCREEN, 900);
						SetCtrlAttribute(panelvy, VYSKA_GRAFVYS, ATTR_HISTORY_BUFFER_SIZE, 10*900);
						SetCtrlAttribute(panelvy, VYSKA_GRAFVYS, ATTR_POINTS_PER_SCREEN, 900);
			 			SetCtrlAttribute(panelvyk, VYKYVY_GRAFVYK, ATTR_HISTORY_BUFFER_SIZE, 10*900);
						SetCtrlAttribute(panelvyk, VYKYVY_GRAFVYK, ATTR_POINTS_PER_SCREEN, 900);
Before pressing:
After pressing the chart starts from over and can scroll scrollBar.
I don't want him to start over.
Message 7 of 8
(4,612 Views)
SOLVED
At the beginning of the program, the attribute was sufficient to insert into the body of the "main" function.
Thank you for your help
Thank you for solving "Gaus"
Message 8 of 8
(4,604 Views)
