LabWindows/CVI
StripChart paused for some moment and resumed again
Hello
I have displaying problem for strip chart. I set up x-axis as continuous mode.
I updates the data by using "PlotStripChart(DisplayHandle,Chart[idx].chartCtrl,PlotBuf[idx],2,0,0,VAL_FLOAT);".
It is not happend not always but sometimes the chart looked pause and resumed again with gaps.
If I observed it closely, the values of chart  change very slightly. But X axis label is not changing and strip chart is not shift to left to show new data.
CPU usage is looked okay. I think it happenes more often  for stable data.
Do you have any idea why this is happening?
Thank you,
Momo
 ps. I tired the multithread program and gave up for synchronizing issue.
(4,376 Views)
Duplicated post. See discussion here
(4,346 Views)
