LabWindows/CVI
Struct Use
Dear alls,
I'm a new user in Labwindowsand I've problem with the Structs,
I would like to make (and use) a struct
typedef struct
 char mau[30];
 double valor;
 } estructura;
estructura *estruc[10];
But I don't know what happens, It isnot working properly.
I would like to define a struct with
double valor and char mau[30].
But after to this, I need 10 times of this struct (I don't know if Is it clear?).
For example, Is it possible to use:
estruc[1]->mau="Test";
estruc[1]->valor=123.12;
estruc[2]->mau="Test2";
estruc[2]->valor=999.99;
Do I need the malloc
(3,403 Views)
With some little adjustment your code should work properly.
When defining the struct:
typedef struct {
 char mau[30];
 double valor;
} estructura;
estructura *estruc;
When allocating memory for the struct:
estruc = calloc (10, sizeof (estructura));
I do prefere calloc to malloc since calloc inizializes all fields to zero.
When using struct elements:
strcpy (estruc[0].mau, "Test");
estruc[0].valor = 123.12;
Hope this helps
Roberto
(3,392 Views)
