LabWindows/CVI
Subpanels in CVI like those in LabVIEW
I would like to create subpanels in LabWindows / CVI as in LabVIEW ie where a panel is displayed as a subpanel of a panel that includes it. Where can I find an example?
Maurizio.
Maurizio Bollini
Certified LabVIEW Architect
http://www.met.it
https://www.linkedin.com/in/mauriziobollini/
(3,506 Views)
(3,498 Views)
Thanks Wolfgang.
I'll try it shortly.
Maurizio.
Maurizio Bollini
http://www.met.it
(3,494 Views)
It's been a long time since I played with LabVIEW so I'm not sure this is the correct answer: I suppose the closest equivalent to subpanels probably are CVI child panels: you could try running panels.cws example program that shows you what child panels are and how do they behave.
To locate the example you can run the Example Finder (Help >> Find Examples... menu item) and serarch for 'panels' in the search tab.
What an idiot I am! I saw the discussion as new and replied without focusing on Wolfgang'2 answer! 😏
(3,454 Views)
Thanks Roberto. I have tried all the examples but from what I have seen, the functionality is different. In LV you can define an area where you can make one panel or another appear. In CVI the mechanism is that of parent / child where one panel can host another. It is about having to adapt to what is available.
Maurizio.
*** started in 1993 with LV 4.x and CVI 3.x 😉
Maurizio Bollini
http://www.met.it
(3,444 Views)
I know this is an old thread. But to help people out here there is a workaround. Setup a tab control, hide the tabs (tab control property), delete the tabs (DeleteTabPage) each time you switch panels, and load in your panel via the function InsertPanelAsTabPage. Works great as a sub panel.
(3,265 Views)
