06-23-2011 04:29 PM
I have been using LabWindows CVI version 7.0 on a Windows XP operations system. Earlier to day, I changed my system screen resolution and was working with the applications.
All seemed to work but at some point I ended the session and then restarted. Instead of starting, I get a Message popup that says "Index passed is out of range" and the CVI application quits.
I tried reinstalling CVI from the original distribution CDs. When all was installed I get the same message when attempting to start CVI.
Anyone have a idea what might be wrong??
I vaguely remember having a similar problem some years ago as I think doing something to the windows registry fixed it - but I am not sure.
THanks
Sweeney
Solved! Go to Solution.
06-24-2011 08:34 AM
Well, I tried deleting the registry entries for National Instruments. After that it sarted and appear to work.
PROBLEM SOLVED
