LabWindows/CVI
System_Drawing_Imaging_ImageFormat_Get_Png
Hi
I have the "image" in memory stored in "frame". I tried to transfer this image to file in png format. I am using .NET System_Drawing 2.0 library. The two line commands below should do the job but on attempt to get_png, I get the pop up error as followed
NON-FATAL RUN-TIME ERROR
"c:LabWin\SystemDrawingLib.c", line 99976, col 5, thread id 0x00000ACC
Function CDotNetInvokeGenericStaticMember: (return value == -6595
[0xffffe63d].
System_Drawing_Bitmap frame;
System_Drawing_Imaging_ImageFormat imageformat = NULL;
System_Drawing_Imaging_ImageFormat_Get_Png(&imageformat,NULL);
System_Drawing_Bitmap_Save_1(frame, fileName, imageformat, NULL);
Regards
Shane Buckley
(2,968 Views)
Got the problem solved.
I replaced AForge_Video_NewFrameEventArgs__Create() with
AForge_Video_newFrameEventArgs_Get_Frame(eventArgs,&frame,NULL)
The case is closed now.
Regards
Shane
(2,950 Views)
