LabWindows/CVI
TCP_Disconnect event
I am using tcp library. Wen I shut down my server, how do I know in my CVI
client app, that this has happened. I don't get tcp_disconnect event.
vishi
(4,403 Views)
I haven't seen the behavior you describe; everytime I shutdown the server I get a tcp_disconnect event on the client side. Are you calling UnregisterTCPServer to shutdown the TCP server? Is the returned status negative (error)?
Azucena
(4,403 Views)
No, server is running on some custom hardware, so I just shut down power to
that. I want to detect that if it happens.
vishi
"aperez" wrote in message
news:506500000005000000F1D50000-1042324653000@exchange.ni.com...
> Regards,
> Azucena
(4,403 Views)
One option would be to create a Timer Callback function and inside this callback, call the InetPing() function to ping the server and see if it is available or not.
Manooch H.
(4,112 Views)
I have same type of setup and when power is remover, i get a TCP disconnect.
Are you doing ProcessSystemEvents or ProcessTCPevents while you wait ?
- Make Software User Friendly -
(4,022 Views)
