LabWindows/CVI
TCP communication design in cvi
I use TCP/IP as the way of communication between processes ,I'd like to know :1,To keep on a stable interact between client and host , what time interval could be the preferred ? 2,Due to take on multi thread mechanism in my application , I find when experienced a period of time (about 6 hours) ,my TCP server application can be killed without execuating any quit instruction , I do not know what bug can cause such a problem , because there is no any system error prompt .Please suggest a policy to monitor the bug .3,Does CVi support "Volatile " keyword ? 4, When the host(TCP server) transmitting data to the client ,can I send back data to the host at the same time ? I am afraid that if there would be a collision of transmitting .
Da
vid
(2,944 Views)
David,
Why not use datasockets? Using TCP/IP, you will have to come up with
protocol to transfer commands & data from your client to server and back.
Why should you worry about collisions in your app, the underlying
protocol takes care of that.
vishi
davidLee wrote:
> Hello,
ease
> David
(2,944 Views)
